kosti89
Post 2241 von 2.543
1.824 Ansichten
Betreff: Fehlercode 11180, help needed
Yes, I tried all these steps several times but it didn't solve the problem. It looks like it correctly find all the channels but it does not allow me to continue forther with the configuration
kosti89
Post 2242 von 2.543
1.828 Ansichten
Yes, I tried all these steps several times but it didn't solve the problem. It looks like it correctly find all the channels but it does not allow me to continue forther with the configuration.
Post 2243 von 2.543
1.826 Ansichten
Work without a hard drive!
Limited operation.
The hard drive stores the channels.
Doesn't work, right?
https://community.sky.de/t5/Receiver/Sendersuche-Fehlermeldung-11180/m-p/830584/highlight/true#M3971...
Can you translate this? Link
Post 2244 von 2.543
1.799 Ansichten
The Q menu is not displayed, right?
Otherwise formatting the hard drive.
Press the “Reset” button until the “Bootloader” menu appears.
Press the “Home” button on the remote control until you reach the “Factory reset” point.
It still doesn't work?
You have to replace the hard drive?
After that.
Moderator (or selfservice; https://www.sky.de/hilfe/geraete/fehlerbehebung/sky-q-receiver/hinweis-17010 ? for example)
Please wait!
kosti89
Post 2245 von 2.543
1.779 Ansichten
Thanks a lot! I will wait for a moderator
Post 2246 von 2.543
1.717 Ansichten
Re: Betreff: Fehlercode 11180, help needed
Hi @kosti89,
unfortunately we can't help you. 😞
Please contact Vodafone for a check:
- Is your cable connection fully activated?
- Is the antenna socket on the wall may be defective?
It would be best if a technician came to your home.
Regards, Sanny
Post 2247 von 2.543
1.712 Ansichten
Haben wir getestet! Schau mal.
Es funktioniert alles ohne Receiver:
Sendersuche wird nicht abgespeichert, daher hatten wir die Festplatte in Verdacht!
@kosti89 Scheint den Selbsttauschlink nicht "bedienen " zu können.
Zitat:
If I connect without receiver it finds all normal TV channels
@Sanny_G
kosti89
Post 2248 von 2.543
1.710 Ansichten
Hi Sanny,
Thanks a lot for your reply. There is no problem with my cable connection because I did not have this problem with my old SkyQ receiver. Also as you can see from the picture, the new device also finds all the channels after the screening but I cannot continue with the configuration. I also contacted Vodafone and there is no problem from their side.
it is truly sad because I am a sky customer since more then 8 years and now I'm thinking of canceling my contract if a solution is not found.
thanks a lot for your support
Ronald_S
Post 2249 von 2.543
1.645 Ansichten
Hello @kosti89, please send me a private message with your customer number and the date of birth and the name of the bank specified in the contract, for comparison. To write to me by private message, click on the link: https://community.sky.de/t5/notes/composepage/note-to-user-id/70608
Greetings, Ronald
kosti89
Post 2250 von 2.543
1.635 Ansichten
Thank you so much! I send you the info
Samka87
Post 2251 von 2.543
1.826 Ansichten
Kein Sat-Empfang / kein Gerätetausch?
Seit einigen Wochen haben wir immer wieder Probleme mit unserem Empfang am Sky q Receiver. Zunächst waren die privaten HD Sender kurzfristig weg, sie kamen von alleine zurück, anschließend war kein Empfang mehr auf den klassischen Sky Sendern.
Nach reset und Werkseinstellungen war nur noch eine handvoll Sender da. Ein Besuch vom Techniker gab uns Auskunft, dass unser Sat-Signal / Qualität selbst bei schlechten Wetter im sehr guten Bereich liegt. Wie durch Zauberhand lief dann für wenige Tage auch wieder das vollständige Programm, wenn es auch zwischendurch Mal ruckelte.
Nach erneutem Ausfall die Sky-Hilfeseiten in Anspruch genommen, die einen Austausch der Festplatte empfahl.
Da erneut die Sky-Sender nicht empfangen werden (alle anderen Sender in hervorragender Qualität) habe ich dann die Festplatte getauscht und... seit dem wird auf dem Sky Receiver 0% Qualität/ 0% Signal angezeigt. Auch mit der alten Festplatte werden nun keine Sender mehr angezeigt.
Am gleichen Sat-Anschluss habe ich einen alten Receiver angeschlossen der Sender empfängt und ebenfalls läuft auch der Fernseher, wenn das Sat Kabel direkt in diesen gesteckt wird.
Den receiver haben wir zudem an einer anderen Sat-Dose angeschlossen und es wurden ebenfalls angezeigt 0% Signal und 0% Qualität. Als einzige Option bleibt den Sendersuchlauf zu wiederholen, da man gar nicht erst in das Menü kommt.
Der Sky Hilfechat empfahl mir nun erneut einen Techniker zu bestellen, da ein Empfangsproblem vorläge. Jedoch funktionieren die Receiver der anderen Mieter, die an der gleichen sat Anlage angeschlossen sind und auch der bereits vor Ort gewesene Techniker in der letzten Woche konnte kein Problem feststellen.
Ich gehe somit von einem defekten Receiver aus. Es erfolgt jedoch kein Gerätetausch. Was soll ich tun?
Post 2252 von 2.543
1.813 Ansichten
Betreff: Kein Sat-Empfang / kein Gerätetausch?
Das kann ich nachvollziehen.
TV und anderer Receiver mit Empfang, allerdings nur unverschlüsselte Sender, was zeigen die so an Empfangswerten an, an diesem Anschluß?
Die Empfangswerte bei deinem Sky Q, die werden beim Sendersuchlauf angezeigt?  Auch wenn ich nur einen Kabelreceiver hatte, es hat gedaurt bis da was passiert ist. Du schriebst ja auch nicht wieviel Sender der Sky Q bei einem Sendersuchlauf gefunden hat (haben könnte).
Wird irgendein Hinweis/Fehler angezeigt?
Nutzen die auch den Sky Q?
Kannst du deinen Sky Q da testen?
Samka87
Post 2253 von 2.543
1.805 Ansichten
Der Sky-Q-Receiver findet mit beiden Festplatten überhaupt keine Sender mehr. Er startet den  Sendersuchlauf und zeigt für etwa 40 Sekunden 0% Qualität / 0% Signal an.
Der Suchlauf wird dann abgebrochen mit der Fehlermeldung 11180 (glaub ich). Als Option gibt's dann nur den Suchlauf erneut zu starten.
Vor dem Festplattentausch hat der SkyReceiver regelmäßig  bei dem Signal zwischen 78 und 100% angezeigt und auch bei der Qualität über 80%. Zwischendurch fand er dann nur 250 Sender, dann wieder 700 und schlussendlich die bekannten knapp 900, ohne dass die Sat-Schüssel neu eingestellt wurde.
Der Techniker maß ähnliche Werte an seinem Prüfgerät.
Post 2254 von 2.543
1.799 Ansichten
Tausch den Receiver selbst! @Samka87
https://community.sky.de/t5/Receiver/Sky-Q-Receiver-haengt-sich-auf-kein-Empfang-mehr-laesst-sich-ni...
Unten hast du den Tauschlink.
Dann hast du komplett getauscht.
Teste noch, wenn du willst.
Ja, meist ist es die Festplatte. Hast du ja getauscht.
Empfangsprobleme schließt du ja aus.
Die Anschlüsse der Festplatte, im Q, sind nicht "verbogen", oder "zu"?
Du kannst zur Probe auch jede andere andere 1TB Festplatte verwenden, auch SSD (hier Probe ohne Rahmen)
Formatiert der Q neu.
Rücksetzungen nochmals und Festplatte neu formatiert?
Post 2255 von 2.543
1.780 Ansichten
Der hat die Empfangswerte nach % beurteilt? Sehr merkwürdig, für den sollten die dB Werte maßgeblich sein.
Hm, die Pegelwerte zischen 78 und 100 find ich persönlich auch für Sat zu hoch, bei der Signalqualität sollten da schon 90 und höher angezeigt werden.
Ein zu hoher Pegel ist genauso schlecht wie ein zu niedriger Pegel.
Beachte, auch wenn der TV oder ein Receiver da die Sender anzeigen, die Sky Sender, die ÖR Sender, die Privaten, die sind alle auf unterschiedlichen Transponder. Dazu kommt der Sky Q ist zickig wenn dem der Empfang nicht passt, da hilft es wenig wenn andere Geräte funktionieren.
Der andere Gedanke, sollte es wirklich ein Problem mit dem TV Empfang sein, dann dürfte ein Tauschgerät wenig bringen.
leoniemutz
Post 2256 von 2.543
1.779 Ansichten
der Sky Q STB brauch unbedingt Astra1 19,2 grad ost ausrichtung
laut internetseite Sat index sollte jedes gerät mit dieser Einstellung 890-900 Sendern haben.
Als kleine Hilfestellung am eigenen TV mal testen, aber dort im Suchlauf auch unbedingt manuell nur astra1 suchen, nicht alle Satelliten auswählen.
es ist halt immer sehr einfach alles gleich auf dem receiver zu schieben
Post 2257 von 2.543
1.779 Ansichten
Habe erlesen, der Userreceiver findet keine Sender.
@Samka87und bricht den Suchlauf schon ab.
Oder ?
" Er startet den  Sendersuchlauf und zeigt für etwa 40 Sekunden 0% Qualität / 0% Signal an"
Das hat dann mit dem Empfang eigentlich wenig zu tun.
Dann hätte kein weiteres Gerät alle Sender. Selten?
Das hat der User doch schon  getestet @leoniemutz .
Andere Meinung?
Samka87
Post 2258 von 2.543
1.757 Ansichten
Genau, seit dem ersten einlegen der neuen Festplatte findet der Sky-Q keinen einzigen Sender mehr und bricht den Suchlauf nach etwa 40 Sekunden ab.
Zuvor liefen mit der "alten Festplatte" alle Sender bis auf die Sky-eigenen (also Sky sport News, sky crime, sky abc...). Jetzt laufen mit der alten Festplatte auch diese Sender nicht mehr. Weiter als zu dem Suchlauf komme ich nicht. Vor ein paar Wochen liefen die privaten Sender in HD nicht.
An den Kontakten der Festplatten / dem Receiver kann ich mit meinen laienhaften Augen nichts erkennen.
Was genau der Techniker alles gemessen hat weiß ich leider nicht mehr. Er gab mir zu verstehen, dass er ein Empfangsproblem nicht feststellen kann.
Interessanterweise und für mich völlig unerklärlich liefen nach dem Besuch des Technikers auch die Sky Sender wieder, obwohl an der Sat Schüssel keine Veränderungen vorgenommen wurden - leider jedoch nur für 3 Tage.
Post 2259 von 2.543
1.749 Ansichten
Deshalb, bei dieser Aussage, tausche den Q Receiver selbst!
Link
Probiert?
Formatiere die Festplatte nochmals!
In meinem Link der Unterlink Festplatte.
Und ich bin ein User der Tausch Receiver selten schreibt. Mach!
"Interessanterweise und für mich völlig unerklärlich liefen nach dem Besuch des Technikers auch die Sky Sender wieder, obwohl an der Sat Schüssel keine Veränderungen vorgenommen wurden - leider jedoch nur für 3 Tage. "
Wackelkontakt nach profihafter Rücksetzung bestimmt? Festplattenaufnahme oder Chip, Anschlüsse?
Post 2260 von 2.543
1.724 Ansichten
Selbst mit der alten HDD hats nicht so wirklich funktioniert?
Sky Sport News HD und Sky Crime HD sind über Sat auf unterschiedlichen Transponder.
Hat der Techniker nur gemessen oder/und auch Veränderungen an der Anlage vorgenommen?
Selbst wenn's nur für 3 Tage funkioniert hat, vorher und nachher Probleme, der Sky Q ist der gleiche.
Mein Gedanke dazu, liegt es dann wirklich am Gerät? Mal gehts mal nicht?
Wirst du auch nicht, aber wenn sich die HDD bündig einschieben läßt sollten die Kontakte in Ordnung sein.
Egal, lange Rede kurzer Sinn, @Samka87 versuch das Gerät zu tauschen, dann sehen wir weiter.
