17.07.2020 13:44
Hi, sorry to do this in english, but My German is justy not good enough.
I got a Sky Q Receiver at home (got it about 2 months ago), and I just got a Sky Q Mini now as well. There is however absolutely no way that I can get the Mini to connect to the Sky Q receiver. There is no WPS botton on the receiver.
The Sky Q box is connected with cable to the router in the house
I have tried via Wifi in the beginning (same router) but as that didn't work I have also tried to have both the Q and the Q Mini directly connected to the same router with cables, but the mini still cannot connect to the Q box
I can get the new Mini to show up on the screen and search for the Sky Q box, but it cannot find it.
I cannot see the sky Q Mini on my Gerate liste either, where I currently only have two other devices out of the five possible.
So question is if the Sky Q box I have actually can connect with a sky Q Mini at all, or whether I need another Skly Q box ?
Or can someone tell me why this is not working, and if I can somehow get it to work ?
All the Best
19.07.2020 13:42
19.07.2020 17:16
Because the Sky Q Mini has to get the sky programmes from the Sky Q, this should happen via the router. Without a connection no TV 😞
I ,mean this is what the instructions tells me to do, but it also tells me to press the WPS on the Sky Q, and the Sky Q I have has no WPS botton at all only the Sky Q mini has one.
Sky is also not selling the Sky Q Mini anymore, perhaps that is the reason, I mean that the Sky Q no longer can connect to a real Sky Q Mini. When I see pictires of other Sky Q boxes on the internet some of have the WPS botton on the front.
21.07.2020 14:31
22.07.2020 11:49
How does that work ?
Where will the mini get the programmes from, and without a card how can I watch anything .. sorry but this is not right. I need a Sky Q box with WPS, is it possible to change the one I have to one with WPS ?
22.07.2020 12:10
Sky Q Mini – Was ist das?
Sky Q Mini in Verbindung mit einem Sky Q Receiver
Sky Q Mini ist eine abgespeckte Version eines Sky Q Receivers und könnte auch “Multiroom IP-Box” genannt werden. Mittels Sky Q Mini kann ein bestehendes Sky Q Abo einfach auf einen weiteren Smart TV erweitert werden, ohne dass man gleich einen zweiten, großen Sky Q Receiver (mit Sat/Kabel) als Zweitreceiver anschaffen muss.
Sky Q Mini funktioniert nur in Verbindung eines Sky Q Receivers und funktioniert ausschließlich via Streaming.
22.07.2020 14:27
22.07.2020 14:36
Hello ClausVanggaard,
you can't connect the Sky Q Mini directly to the Sky Q Receiver.
To use the Q Mini you have to connect it to your Internet-Router via Ethernet or WLAN first.
When the Q Mini is connected to the Internet, you must connect the Q Mini with your Sky-Account. The Q Mini will ask you for your Sky-Login-Data.
After that is done, your Sky Q Mini should work.
Please mind that it only works, when the Q Mini and the Q Reciever are connected to the same Router.
22.07.2020 14:37
Exactly, they are on the same network, I even tried plugging them in with cable in the same router,. The Sky Q Mini only gets the the information from the Sky Q Receiver as the programmes are not sent to me over the internet but collected in the Sky Q box from the kabel connection. The Sky Q Mini does NOT connet via an APP to Sky like a mobile device, it connects to a receiver. So if the Sky Q receiver I have cannot communicate the information by connevting with the Sky Q Mini, then I have no programmes on the Sky Q mini. So, is it possible to get a Sky Q receiver with WPS so that they can connect ?
22.07.2020 14:42
Thanks Papa,
The Mini I have does not ask for login data .. 😞
22.07.2020 14:52
Can you navigate to the Settings-Menu "Mein Sky Q"?
There you should find a possibility to "Login".
22.07.2020 14:54
22.07.2020 15:36
I think it would help us a lot if you could upload pictures of the problems you described here, because I can't understand your problem at the moment.
22.07.2020 15:54
Thanks all, will try again for the 10th time but I simply don't get past the message where I have to connect to the Sky Q Receiver, and eventually just get a failure mesage that it cannot connec to the Sky Q receiver.
Will take some photos perhaps that will help.
Thanks again so far
06.08.2020 21:26
Unfortunately I don't get that message or possibility, and every sub menu only states that there is no connection to a sky Q box.
09.08.2020 16:27
