SKY Q IP Box weiterhin völlig instabil
leon_panda
Post 21 von 21
368 Ansichten
Re: Betreff: SKY Q IP Box weiterhin völlig instabil
Hello
Yeah, I know that, but the frame rate is still off.
Just compare it to Zattoo, Waipu or MagentaTV. One thing is the resolution, and another one are the FPS and this is where the stream fails.
Also, it was fine before. So something happened along the way, but up until a month ago, FPS were fluid.
Edit: I'll capture some footage directly from the Sky Q box and upload it later for you to see the difference.
