13.10.2018 11:09
hello, how do I delete a program that I have watch but it’s still showing up in Fortsetzen ?? and how does the new sprach function work ??
Joe
13.10.2018 11:29
Details regarding this new Remote Control are declared here
Die neue Sky Q Sprachfernbedienung ist da
But everything is in german language. I don't know in case of ordering the new Remote Control, if there will also be instructions in english language and generally, if it will be possible to choose different languages like english for this new part.
However, it will only work with Sky Q Receiver.
13.10.2018 11:50
As user of Sky-Ticket I learned, that the only way to remove a program from the "Fortsetzen"-List is to end it. With series, you have to choose the very last episode and end it (e.g. ind fast--forward-mode).
Maybe it works the same way with a receiver.
14.10.2018 11:33
thanks for the info but it didn’t work
14.10.2018 11:58
For Sky Ticket this should work as sur said. For instance on Android go to "Weiterschauen", then select your content to resume and let it finish to the end (you can even move the progress bar to ~ 1 minute left and then let it finish. By this it gets removed from the "Weiterschauen" list. Currently there is no other way (no option to remove it manually). This would be a good improvement in my opinion. However, this is the only way right now.
14.10.2018 19:25
I got a contract with sky not a ticket so it dot work for me the way u are saying but thanks anyhow
holgerhees | 25.04.2024 14:17 | ||
Tisirbe | 19.04.2024 11:48 | ||
sonic28 | 17.04.2024 13:38 | ||
BerndHeinrich | 13.04.2024 20:31 | ||
sonic28 | 09.04.2024 09:15 |
