Sky Ticket Player not playing
Highlighted
Post 1 von 19
1.840 Ansichten
I am on a Macbook with OSX 10.12.6. I have uninstalled and reinstalled the app. I have deleted cookies/browsing history of my browser. However, when I click "play" it opens my sky ticket app and then the app displays a message that says "Du has noch nicht genug? Stöbere durch unsere Inhalte und schau gleich weiter." If I click the button, it takes me back to my web browser and the loop continues. It will not play any content.
Please help?
Highlighted
Post 2 von 19
1.299 Ansichten
Re: Sky Ticket Player not playing
Been there, done that but fortunately that's an easy one
As soon as the player opens and the message shows, you just have to wait some more seconds and DON'T press the button. A few moments later you will se the rotating dots and the chosen content will start
Highlighted
Post 3 von 19
1.299 Ansichten
Hi,
Thank you for your reply. However, I've waited for a long time (20 minutes) and no content plays. That screen just stays and no rotating dots come.
Highlighted
Post 4 von 19
1.299 Ansichten
Sorry to hear
I haven't had this before. Hopefully there's an iOS-User or some Admin to help you with that.
Highlighted
Post 5 von 19
1.299 Ansichten
try another browser ? for example chrome.
Highlighted
Post 6 von 19
1.299 Ansichten
I have tried both Chrome and Safari. I don't think it is my browser as it is launching the Sky Ticket app. It seems to be a problem with the app itself? I closed all my other apps in case there was something interfering with it. It was just Chrome and Sky Ticket app and it still didn't work.
Highlighted
Post 7 von 19
1.299 Ansichten
why do you use the app from the store ? is it not possible to use the ticketplayer from the desktop ? ticket login and then download of the ticket player ?
Highlighted
Post 8 von 19
1.299 Ansichten
No, I used the app from SkyTicket.de and then it downloaded and installed the "app." It is a seperate program that runs outside of my browser now.
Highlighted
Post 9 von 19
1.299 Ansichten
they say sometimes its neccessary to clear the cache und delete cookies, and maybe neccessary to
delete the ticket player and cisco videoguard and clean the registry
before new downloading the ticket player
Highlighted
Post 10 von 19
1.299 Ansichten
I tried deleting cookies, and cache. I deleted and re-installed. I tried restarting. What is cisco videoguard, where can i find it to remove it? What registry must be cleaned?
Highlighted
Post 11 von 19
1.299 Ansichten
paulesteves schrieb:
... It is a seperate program that runs outside of my browser now.
Sure, but there has to be some "handshake" between browser and app that obviously doesn't work out properly.
After selecting a content within the browser, ther ought to be two things to happen: the launch of the app and start of the previously selected content.
As it seems, this second part is the problem. This might be due to a bug on the sender's (=browser) or the recipient's (=app) side. Unfortunately it will need someone technically mor able than me to work that out.
Highlighted
Post 12 von 19
1.299 Ansichten
...What registry must be cleaned?
If I were you, I would not meddle with the registry. There's a fair chance to mess things up, if you are not a pro on that.
Highlighted
Post 13 von 19
1.299 Ansichten
there are programs like Glary Utilities which can do that. If there are remains of former deletes some things will not perform.
Highlighted
Post 14 von 19
1.299 Ansichten
if someone is using sports or films with ticket player may be its neccessary to close other streamings or downloads at the same time.
Highlighted
Post 15 von 19
1.299 Ansichten
Did you try to delete temporary Data from you mac? (Not browser)
Finder -> Use go to folder - ~/Library/Caches -> Enter
Highlighted
Post 16 von 19
1.299 Ansichten
I will try this tonight when I am home, thank you kindly!
Highlighted
Post 17 von 19
1.299 Ansichten
Best of luck for you
If its not helping in any way, maybe I have one or two more tips for you to try afterwards
Highlighted
Post 18 von 19
1.299 Ansichten
entzückend
Highlighted
Post 19 von 19
1.299 Ansichten
Unfortunately this also did not work. I would love any other suggestions? It is now day 3 and I can't watch anything on sky ticket, how frustrating.
