16.05.2021 13:46
Hi,
how can I watch sky on Macbook ? It is asking for skyId , and it does not accept my kundennummer or my email id. So waht is the skyID, or is there any other way to watch it on Macbook ?
Thanks
16.05.2021 14:21 - Zuletzt bearbeitet: 16.05.2021 14:30
The ID from Sky is your customer number. You can also use your email adress. Is your pin code correct?
To watch Sky on your MB you only need your login and the Sky Go app from the Sky homepage.
Or do you have Sky Ticket?
greetings
Christian
17.05.2021 12:16
Hello @syparth,
have the tips from @Chrille610 already helped you? Were you able to set a Sky PIN for the login? This is how it works: https://bit.ly/3hCbb1v
If you are a new customer please select "Sky PIN registrieren".
If you have forgotten your PIN, please select "Sky PIN vergessen/gesperrt".
Regards,
