TV shut down
calif
Post 1 von 11
931 Ansichten
TV shut down
My Sky Q receiver goes down and then Sky Q reloads programs.This happens a few times per week.
Does anyone experiences this?
Thanks
BenjaminM
Post 2 von 11
889 Ansichten
Re: TV shut down
Hello @calif,
does the receiver restart automatically or do you have to do a reset? Sometimes the hard disk can cause this problem. Please remove the HDD from the receiver and check if the error still continues.
Regards,
Benni
calif
Post 3 von 11
885 Ansichten
Re: TV shut down
Thanks for the tip benni,
it loads automatically but I have to keep pushing the Q box on/off button for it to start again.
I'll give it a try.
BTW, my hard disk is new.Sky had just send me a new one.
As I mentioned, it only does it with the Sky F1 HD channel.
miregal
Drehbuchautor
Post 4 von 11
868 Ansichten
Re: TV shut down
Hi Calif, do have an UK Sky receiver? Thsi Forum is for German Sky only (Sky DE Q box does not have a power button).
calif
Post 5 von 11
855 Ansichten
Re: TV shut down
No, I have a German Q receiver. (I am American and unfortunately cannot write in German)
the on/off button I meant the button on my remote.
KatjaZ
Post 6 von 11
842 Ansichten
Re: TV shut down
Hi @calif
have you had time to test it without a hard drive? If so, does the problem occur without the hard drive?
Regards,
calif
Post 7 von 11
838 Ansichten
Re: TV shut down
Thanks Katja,
No, I have not tried it without the HD, but will do so.
By the way, just this last week Sky send me a new H.drive.
hard to believe that this new one is defective.
It only happens on some Sky channels. Other ones like CNN, ARD/ZDF and others are okay and with those it never happens.
KatjaZ
Post 8 von 11
831 Ansichten
Re: TV shut down
@calif,
thank you for your feedback. The hard drive test should narrow down the problem a bit more. 🙂 Does this interference occur permanently on the channel Sky Formula 1 HD? Can you name other channels where the problem occurs?
calif
Post 9 von 11
828 Ansichten
Re: TV shut down
It happens very frequently on the Sky sport F1 HD channel. 3~4 times per hour and yesterday 1 time on 3Sat HD.
a few weeks ago it did it also on some other Sky sport channels ( before I received a new hard disk)
BenjaminM
Post 10 von 11
822 Ansichten
Re: TV shut down
Hello @calif,
when the problem without the HDD still exists please contact me in a private message. Then i will send you a new receiver.
To write me a private message open my profile and click on "Message" (in German: "Nachricht").
Regards,
Benni
calif
Post 11 von 11
814 Ansichten
Re: TV shut down
Thanks Benjamin,
I will try it as you suggest and will let you know the status.
again, thanks for your assistance regarding this matter.
have a great evening.
