Skyticket shows "Fehler Code 9004 0xfd80006b" since 6pm
troytang
2.885 Ansichten
Hello German Users,
I live in Germany and tried to finish my movie on Skyticket. Then it showed "Fehler Code 9004 0xfd80006b" since 6pm today.
I restarted my skybox (Ruko) and it still has the error. I also logged out and logged in with my account.
Then I tried the Web skyticket and I got the same error.
Is it a server issue at the moment?
Thanks!
Cheers,
Troy
1.322 Ansichten
Re: Skyticket shows "Fehler Code 9004 0xfd80006b" since 6pm
Update 20:00:
The problem has been identified and solved but it could take another 2-3 hours to provide the content again.
1.322 Ansichten
Unfortunately there is a general problem with the access to all streaming content since early evening (Streaminginhalte derzeit nicht abspielbar)
If there are news available, I'll have you posted
1.323 Ansichten
Update 20:00:
troytang
1.322 Ansichten
Thanks for the timely update and support! Appreciate your work and follow-up !
I wish that the Skyticket tech team could be as great as the support team .
I am looking forward to the contents.
