04.07.2021 15:17
My Sky Q receiver frequently shuts down by itself and reloads.
very annoying.
it seems to do this only on Sky Sport F1 HD and,in addition,when I change to Sky Sport F1 on UHD.
please help.
thanks
23.07.2021 08:10
Has anyone already helped you with your problem or are you still trying to do anything against it by yourself?
The problem you described, sometimes happens to my Sky Q-Receiver, too. But its independent on which channel I´m watching Sky, when it comes to shutdowns. But I can tell you, that I had picture problems on the channels Sky Sport F1 HD and Sky Sport F1 UHD during the race in Silverstone last weekend, then the Q-Box hung up and I had to restart it.
Do you have any picture problems before it comes to these shut downs?
23.07.2021 08:27
I had the exact same problems you describe.
in the meantime, Sky have provided me with a replacement Q receiver and hard disk.
everything is cool now and have no longer any problems.
23.07.2021 13:55
Hallo @borussiabvb2020, please give me your customer number by private message. To contact me by private message, click on my profile and then select "Message" under "Contact me". Greetings, Ronald
23.07.2021 21:01
Mine started doing this 2 weeks ago and didn't do again til today, when I tried to watch amazon prime, then when I tried to watch uhd and then again when I was watching sky sports..
was told to reset and update none of which worked...
What next?
23.07.2021 21:20
At the end Sky provided me with a replacement Q receiver and new hard disk.
that did the trick and no problem since.
